great bass small space
ax600
Hello, everyone I have a sub box that is 2.5 cuft and measures 13x29.25x11.75. inside. I have a new rockford power hx2 15'' sub that I would like to use in this box. The problem I am having is that , I am unsure as to what the port sizes should be to tune to 33hz. Can anyone please help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . currently I am using this box with two 4'' ports 18'' long //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif , but I think that there is room for improvment. Any help would greatly be appreciated. thank you.
Ok so port volume is easy to figure out once you discover the 12 volt . But once you get the port lengh can you just divide that number by two if you wish to run two ports? so one port 54'' or two ports 27''.
easy the dimensions are inside peramiters. the outer ring on the sub over laps a little,reason being that I dont have very much space to work with.the outside of this box measures 31.5x14.5x13.
Can my ports be run outside this box to take up less volume inside the box?Does any one have a formula for that? I am getting realy good at talking to my self. Oh well at least it gets my number up there a little.
ax600
ax600
grand forks N.D.
ax600
