Govenor Eliminator
And there is no way your audio bangs louder than my 4 1ohm stable audiobauhn 12's w/custom fiberglass rear seat replacement. Also alluminum spoilers are for customizers not street racers ***.
but anyone that knows anything about cars knows that a govenor runs off your tire spec's if you get better rims and tires going over 110-120 is not an issue unless you have a govenor which on GM's cuts you off at 108 mph. i hope that satisfies you on all your inqueries sir
Only thing I can say about your stereo is.... //content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
As far as the govenor, the new vehicles have electronic transmissions which send info to the computer, the computer matches the programmed rpm and gear to the cut off of the vehicle. Tire spec does play a role smaller tires=lower top end. As far as 108 cut off my truck and every other GM vehicle I have had was 98 to 99 mph.
One last thing "SIR" bauhn sucks and your calv blows a$$
Also Mr. Speaker Guy What Is So Much Better About Having An Illiegal Sound System If You Can't Hear The Emergency Vehicles Getting Ready To Come Up Behind You Or W/ Any Luck Hit U
All GM vehicles with a computer have a plug under the dash by the glove box that can be bypassed to turn the limiter off. Basically the exact same thing he stated but with less work. All it does is turn off the coil/fuel management restrictors allowing for higher RPMs,more fuel consumption. The down side is at low RPMs you dont have full computer control of the timing.
so where can i get this done at.
All That Plug Is Good For Is Getting Your Trouble Codes Not Poss To Bypass Any Govenor Unless You Can Change Your Chip Which You Can't In 02 And Up Gm's
YOU CAN'T GM DOES NOT ALLOW IT B/C IT IS AGAINST THE LAW. THE ONLY WAY YOU CAN IS IF YOU SWAP A REPROGRAMED ECU FROM AN EARLIER YR THAT DOES NOT HAVE THE GOVENOR WHICH IS GOING TO REALLY COST YOU BIG
Dumb *** the trouble codes are checked in the diognostic port under the driverside dash. The wire I am talking about is a single brown wire with a clip for timing and fuel adjustments.
Carlo97 I honestly wouldnt suggest it. You would be better off getting a chip or reprogramer.
Carlo97 I Can Garuentee You There Is No Wire Like That In Any 02 And Up Gm Cars Or Trucks. This Guy Is Stupid And Has No Biz Talking About Cars. Stick To Yur Speakers Jntar. And Why Does Everyone Have Such A Big Deal About My Caps. Just Read The Comments!
Also If There Even Is A Brown Wire If You Cut It You Run The Chance Of Ruining The Electric System. The Mod I Suggest Has Been Done Many Many Times And Never Any Hardware Or Software Problems, This Mod Is For Your Benefit I Only Wanted To Share Some Wisdom To Those That Want It. If Your Not Interested Than Back Off
Its not illegal. How is it illegal? You are simply disconnecting the computer timing. And last time I checked pre 1988 GM vehicles did not even have a computer.
One Last Thing. I Rreally Dont Know Jack About Stereos. I Really Know Verry Little That Is Why I Am Here. But, If There Is One Thing I Do Know Its Cars. You Really Need To Grow Up. Get A Role Model And Learn How To Use The Fu(king Caps Lock.
You dont cut it you unplug it. I am through with you.
VERDIKT
VERDIKT
COLUMBUS, OH
UndercoverPunk
tyler0508
    May 27, 2026
ThxOne
    May 25, 2026
