Got these Orange Farenhiet 12's......R They N E Good?
Donks
I just got these orange farenhiet 12's i cannot find the ratings on these, but i looked and seen they are dual voice coil though. I got them hooked up on a small white AMP called Crossover its 300x2. I dont have it bridged either and they low key WANG!
i searched this internet and found that the 15 inch sub is 1200 watts rms and 2400 watts peak power.
and on another site the guy said that the 12's are 2000w a piece. which im guessing is 1000w RMS.
HERE IS THE SITE WITTH THE PICTURES THAT LOOK EXACTLY LIKE MY FARENHIET SUB
http://www.autotrader.com.au/iteminfo/adnumber_WB2763285750_cat_Car+Audio_loc_locRZSQregtAVSCdistRZSQAVSCstateRZSQ9AVSCregRZSQ_off_13_sect_Automotive_sort_otRZSQ1BJDZfdRZSQSearchDisplayPriorityIndAVSCotRZSQ1BJDZfdRZSQFirstPublished_sqt_1_stpg_1_subs_Wheels,+Tyres,+Parts+&+Accessories_
Come on you guys whats this sub? dual 4 ohm or dual 2 ohm.
you had better go get one of those little digital battery powered multi meter things
with the dial on it. that way you can test all your electric stuff with it.
if you happen to wire up your subs - and dont check them with the ohm meter before
playing them with your amp - you could start a fire. seriously.
wire a pair of dual 4 ohm subs up to run at 1 ohm load on the amp - and use an amp that is only capable of playing at a 4 ohm load and watch it catch on fire. do it.
the $20 I spent on my digital multi meter was the best car audio investment ive ever made.
- can also check battery voltage with car running and off.
and test subs with it to see if they are burning out - or burned out completely
Donks
Donks
CO, Ohio
Donks
