TBird93
Hello all,
I just got a Planet Audio VX-6002 and I had it hooked up to 2 Orion P-series subs. Dual 4 ohm. I had them wired in two channel mode at 2 ohms a piece and everything was cool. The first night I had the amp it pounded pretty hard, then the second day I was riding around and the amp started going into protect, it would go in and come out. I tried to shut it off and let it cool, but even when it was cold it would still do the same thing. I don't have to much experience with a DMM but I do own one and I did a quick search around here for some info.
I don't know if I did it right but I hooked the DMM up to one channel and it measured .04 volts, then I hooked it up to the other and it measured .018 volts. This is with the volume at a low level. I tried to wire the subs up to 4 ohms and then bridge them at the amp and it would immediately go into protect when I turned it up very slightly. Can anyone help me figure out what is going on? Thanks.
