Got my new PP 900.4. Manual makes no sense
66ca
I got this in today.
I plan on running the front channel to power my door speakers and bridge the other channels to run the single 10 I have. The manual doesn't say how to do this.
I've hooked up plenty of amps and stereos before, but it's been a while and don't remember how to bridge it.
Does anyone have one of these or can tell me what to do?
take the positive of channel 3 and the negative of channel 4 and voila! bridged. The manual seemed pretty straight forward in mine. Were you looking in the right section? Cause it is like 4 manuals in 1 because it has all the info for the other phantom series amps as well
I got this in today. I plan on running the front channel to power my door speakers and bridge the other channels to run the single 10 I have. The manual doesn't say how to do this.
All you have to do is wire the front up in stereo to your front speakers with the HPF (Unless you have hpf set on your HU already, then you can just run full & adjust from the HU) and bridge the rear two channels (1 positive from one channel, and 1 negative from the remaining rear channel) to your sub with the LPF & adjust all accordingly - *Note* you need either a single voice coil 4 ohm sub, or a 2 ohm dual voice coil sub so you have an impedance load of 4 ohms on the bridged channels of that amp
66ca
66ca
sherman,tx
NIHL8ION
