Im simplifying my system as well as my future plans for a 3 way active setup.. after some tuning and tweaking, I realized my stereo equipment is plenty capable for my needs, but it just needs a better/different install.. so.. without further ado...
I have one b stock (never owered except to make sure it worked for about 1 minute) elemental designs 16kv.2 15" dual 2 ohm vc subwoofer.. should have about 9 months left on warranty..
Qts .32
Qms 3.60
Qes .35
Re 8.6
Vas (Liter) 162
Sd (cm^2) 545
Fs (Hz) 21.5
Bl 15
MMd 135.00
MMs 142.00
Xmax 15.1mm
Voice Coil
2.5" - (63.5 mm )
Spider
Single 8" Progressive
Tinsels
Woven
Mounting Depth
7.125" - ( 180 mm )
Mounting Diameter
14.00" - ( 356 mm)
Displacement
.08cF -
$70 shipped in conus
I have one d4 (used for about 4 months total under light conditions recieving less than 600 wrms at any time) elemental designs 19ov.2 18" dual 4 ohm vc subwoofer.. cosmetically in great shape, but the little sticker on the bottom of the motor had been removed
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26 Hz
Re: 3.5
Vas: 228 L
Mms: 307 g
Bl: 22.1 T*m
SPL: 90.5 dB
Sd: 1200 cm^2
Xmax: 22 mm
Voice Coil: 62.5 mm
Magnet Width: 8.200"
Cutout Diameter: 16.375"
Mounting Depth: 9.625"
Weight: 42 lb
Total Height: 10.600"
Displacement: .10 ft^3
Outside Diameter: 18.375"
$170 shipped conus
I have a set of dls iridium 3" dome midranges with crossovers (but no grills).. I have not used them as of yet, but they were tested, and are in perfect working order.. I really really really dont want to get rid of these.. Ive always wanted a 3 way active front stage, but, I just dont need it.. ive heard nothing but the best reviews of these midranges, and I hate to let them go.. but I am so, let me know
heres the driver specs.. I cant find the info on the crossovers though.. Ill update when i get it
Impedance 4 ohm
Power handling capacity 100 W RMS
Max power handling capacity 160 W
Frequency range 250 - 8000 Hz
Fs - Resonant frequency 280 Hz
Voice coil 75 mm / 3" Aluminium flat wire, 5 mm
Sensitivity 91 dB (1W/1m)
X-max +- 0,5 mm
Magnet size 80 mm (3,15")
Mounting hole 95 mm (3,74")
Mounting depth 35 mm ( 1,38")
Outer diameter 120 mm (4,72")
160 shipped conus
I also have a couple of elemental designs eqhs 12" svc 2 ohm subs $40 shipped conus
edit - sold to kuztim roder on diyma
as usual with my for sale threads, I didnt bring my camera to work with me, so I dont have pics yet.. should be available tommorrow night about this time, also, Ill be going to Las vegas for my honeymoon (now you know why Im really selling all of this lol) from July 11th to the 13th or so, so I wont be returning any emails or pms about this unless Im bored.. but I plan on much ***, drinking and sin to celebrate my new union so I doubt Ill be bored
let me know..
also, Im open to trades on anything for a class d mono that will give me a ballpark of 1000wrms (ish.. Im flexible) @ 2ohms plus some cash or whatever for my ed 9.1, but I need a smaller footprint if possible.. Im going stealth under seats
any questions or lowballs, put it here or pm/email me
I am open to offers, but Im open to saying no if you do lowball me...
let me know if you're interested, I will work with you
Qts .32
Qms 3.60
Qes .35
Re 8.6
Vas (Liter) 162
Sd (cm^2) 545
Fs (Hz) 21.5
Bl 15
MMd 135.00
MMs 142.00
Xmax 15.1mm
Voice Coil
2.5" - (63.5 mm )
Spider
Tinsels
Woven
Mounting Depth
7.125" - ( 180 mm )
Mounting Diameter
14.00" - ( 356 mm)
Displacement
.08cF -
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26 Hz
Re: 3.5
Vas: 228 L
Mms: 307 g
Bl: 22.1 T*m
SPL: 90.5 dB
Sd: 1200 cm^2
Xmax: 22 mm
Voice Coil: 62.5 mm
Weight: 42 lb
$170 shipped conus
Impedance 4 ohm
X-max +- 0,5 mm
160 shipped conus
let me know..
