got a prob with my amp not turning off
imallthatisman
ok i have a 1988 jeep that doesnt have a clip for the stereo... i got the stereo to work fine but the amp only works when i have it hooked up to the constent power. so my amp doesnt turn off now. also i have my amp hooked up directly to my battery and if i leave my car off long enough, the battery dies! its starting to make me mad... this never happened to any of my other systems
the thing is if i had a remote wire hooked up to my (we'll say speakers) my speakers wouldnt work. my stereo wouldnt work if i didnt have it hooked up the way it is
its hooked up to my constent. so my battery dies. i've tried every wire i could find and there is still no power to my amp without being hooked to my constent
Ok, a remote wire is, what tells your amp to turn on, so if your car is not in the accessory position, then u cannot listen to music,, but if you car is, you can, it is that simple...
~ Kyle ~
if im right there is a blue wire on the HU, that should be the remote turn on (kind of scetchy, havent done a HU install since mine almost two years ago).
al
buchel, I know how to hook up a stereo and what wires do what and why they do. all i need to know now is how i can run a remote wire from the circut bored to my stereo because there isnt one labled MEM or memory
I my self would not wire it up to the fuse box. You do not want to overload your electical system, may causing you to blow fuses or burn wires. Even though your remote turn on lead is pulling less than half an amp. I suggest if you cannot find a turn on lead from your head Unit then to run a toggle switch in line between your constant power and your remote turn on at the amp.
imallthatisman
imallthatisman
missouri
tommyk90
