Gorgeous Massive Audio DMX Stage2 15in. Quad 1ohm, carbon fiber cone/dc, Still Stiff
BassAddictJ
FL
MAssive Audio DMX Stage 2 15in big boys toy
Quote from Snoopdan
"Did my first 150 with a single 15' DMX back in 2006. Totally unappreciated sub."
I'm NOT saying you'll easily do 150db off this one 15, but the potential is there and this is a great piece of equipment. I'm not even sure if the full carbon fiber cone setup is still around. The current website recones are newer/different and not CF looking. Clean power these will take 3kw all day, less than clean power I'd keep it a bit under that. Burps 5kw-6kw no problem, and easy wiring to .25ohm if that's your cup of tea.
I picked this up local to replace my trf/psi beast that's having foam surround issues....but now I'm torn between trying to fix the trf or using this. So up for sale this dmx goes, if it doesn't move I use it and then put the trf/psi up for grabs as is.
This baby is in pretty **** good condition for being a few years old. In fact it's one of the better looking ones than others I've seen posted in the last few years. The only things wrong with it I could find are some very minor blemishes on the outer gasket/basket near one of the mounting holes (shown in pics).
Not a single scuff anywhere on surround, cone and dust cap are immaculate, rest of the body looks GREAT too. all coils read .9 perfectly. Suspension is still a bit stiff, no tears or blemishes on the spiders or coil lead wires. Even the butt of the magnet is shiny and clear. You can see the tv reflection in the pic.
Specs for those who want:
http://www.dnacaraudio.co.uk/massive-audio-subwoofers-dmx-15-stage-2/
Specs cliff notes:
3000w rms quad 1ohm coils
full carbon fiber cone and dust cap
vented cooling
field replaceable recones (no sanding/gluing bs)
200oz magnets / 56lbs
lots of balls
Would like to get 350 shipped OBO. The closer to FL you live the slightly more negotiable I am with the price...
usps insured
hotness:
Those are legit woofers. Know a guy that did a high 50 with two on 8k in a pickup. Maybe not have been TL then, but still impressive. I didn't know the underside of the cone was CF too
good chance that was a TL. I recall TL's being more standardized in the major cicuits by like 05/06. pretty sure and the dmx st2 i feel like came a little after that....anyone else want to add to that?
  • Locked
Hello all, I am new to this forum but have had no luck on ebay/gumtree/fbmarketplace regarding trying to shift my aftermarket car audio setup. My...
  • Locked
hello mate, text me +1 (706) 300 5660 for quick response, if you need the Massive audio 15" dmx stage 2 for sale at a secondhand price, stay safe
It only works if you send rca signal through it to your amps.
986
80a Alt. is your problem....i have a 2017 spark, no way i would go over 1000rms on stock electrical in that thing....and your cap aint doin...
77
BassAddictJ
BassAddictJ
FL
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
