Sold GOOD SUBS + Good amp= great price... (with box)
sick06cobalt
So I know Im new here but it was because I was referred to this site by someone who said I might be able to sell this here easier... Im actually from cobaltss.net under the same name and have alot of great feedback there and my photography forum.
So I have the following,
2 Diamond D3 subs- 12"
Monster Capacitor
Rockford Fosgate T80002 Amp.
Custom built ported box, Great ventilation.
All wires needed to hook up system to the capacitor and battery. Also the cables/wires to run from the amp to the Head Unit/Deck
Amp comes with the Manual gain control.
Im selling because I dont need any of this anymore.. I dont use it and I need the trunk space. It is a great set up for someone who wants some nice bass in the car.
It pushed 141 at the windshield when I finally did push it to its limits.. ( I only did once when i finally had someone with a meter) other than that it wasnt pushed almost at all.. Definatly wasnt abused.
Photos:
I Dont want to ship because of the size..but if the price is right I will. - I AM willing to drive to make this deal..
Here is the information on the system:
Subs
Amplifier
Im looking for 1250-1350 with pick up, delivery will depend on distance...
I am willing to split this up for the right price..
Feel free to ask me with questions and I can try and figure something out.. this is OBO but i mean it is an amazing system.
specs on the amp??
1 ohm mono stable?
Here are some details from the site that i put in the op
Details:•125 watts RMS x 2 at 4 ohms (250 watts RMS x 2 at 2 ohms)
•400 watts RMS x 2 at 1 ohm (1-ohm stable, 2-ohm stable in bridged mode)
•500 watts RMS x 1 in bridged mode (at 4 ohms)
•800 watts RMS x 1 in bridged mode (at 2 ohms)
•CEA-2006 compliant
•Tri-way capable (Tri-Way crossover required)
•requires 1/0-gauge power and ground leads — wiring and hardware not included with amplifier
•variable high-/low-pass filters (40-400 Hz, switchable from 12 to 24 dB/octave)
•Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control
•MOSFET power supplies and outputs
•MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
•TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
•*****-ANA circuitry keeps preamp signal clean
•NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance.
•fan cooled
•preamp inputs and outputs
•fuse rating: 150A x 1
•dimensions: 22-7/8"W x 2-11/16"H x 12-3/4"D
•warranty: 2 years
As long as I have had it, I never had a single problem... it was a great amplifier
EDIT: Everything has NO marks on it.. Box and subs are pristine, as well as the amplifier..
You do know its cheaper to buy new right? I have hard time selling higher end gear(worth more) for less then what you want in this area(STL area), so I find it hard that you will ever sell this.
Monster Capacitor
Photos:
Subs
Amplifier
your coolant seems to be running hot
sick06cobalt
sick06cobalt
Springfield/St. Louis, MO
misfit138
