Good SPL sub with 1000 watts?
bose301s
I can break these cuffs
I am looking to do a SPL box for fun and just use my current Sundown 1000D, nothing over the top. I am looking at getting a used motor, I can get a Mag V3 motor cheap but am also looking at the Nightshades woofercooker has but using only 1 stiff spider, using the SSA Icon motor I have sitting around or finding a used HDC3, Konaki or DD 9500 motor. What do any of you think would provide the best results with my 1000 watts, I am leaning towards the AQ option or the NS option.
that amp isnt big enough for a dd 9500 i had a shity quantium 4000 wired at 1 ohm on a 9515g and it was push n 1500rms tops and it wasnt enough it was loud but hardly moving that sub
too bad you dont have 2kw rms @ 1 ohm id sell you a bnib OLYMPUS 1612 it is a true sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I had an HDC315 on 1200w~ and it HIT... in my cadillac it did a 143.6 on music (young joc, goin' down)
1612 I have heard on a ZX1200 and it got a little stinky after about 3~ minutes... Of course i have no clue how he had the amp set or anything like that...
Olympus 1612:
MAX: 3200 Watts 1600 Watts 2 + 2Whether you are looking for high SPL or incredible SQ, the Olympus series subwoofers are the answer! These subwoofers were designed from the ground up to cater to the needs of audio enthusiasts looking to push their system to the limits. With 3
voice coils for high power handling, large double stacked magnets for increased motor strength and 1
high roll surround for increased excursion, you are certain to FEEL the POWER FROM the GODSwith these subwoofers!
12-Inch DVC Subwoofer
For Ported Enclosures
1-Ohm, or 4-Ohm Operation
76mm Dual 2-Ohm + 2-Ohm Voice-Coil
1600 series 160 oz. High-Energy Magnet
2400 series 180 oz. High-Energy Magnet
Fiber-Glass Infused FEA Structured Cone
Die-Cast Aluminum Chrome Speaker Frame
Multi-Layer High-Temp VC
Front-Plate & Voice-Coil Cooling
Double-Laminated Integrated Spider Tinsel-Lead Design
25.4mm / 1
Hi-Excursion Surround
Push & Insert Wire Terminals
Yea, was considering getting a Mag V3 motor and having TeamPSI put a recone on it suited to what I want. The V3 motor has pretty good motor force and with the correct coil a fair amount of linear excursion, it could work well.
bose301s
bose301s
Durham, NC
bose301s
vegang
vegang
