SOUNDz
to run power wire from battery to + of cap, then 2 wires from same + terminal 1 going to + on 4ch amp and the other to + of sub amp. then from each amps - terminal, a ground wire back to the caps - terminal. then a 3rd wire from cap - terminal to a chassis ground. will ths work? one more ?. if you run a 1500w amp, and a 600w amp and the only fuse u have is a 250amp fuse near battery, can u get away with not using a fused dis. block?
