JessyBoy86
So,
i'm gonna receive a pair of hertz hv165xl today and i'm looking for a pair of tweeters to run them with.
i found those,
http://solen.ca/wp-content/uploads/sb29rdcnc0004.pdf
I found that Solen electronic is around 20 minutes from home and they have a lot of SB accoustic stuff. I would've liked to get a pair of hertz HT-28 but they are kinda hard to get here in Montreal so...
Based on freq response diagram of both the mid-woofer and the tweeter, i figured that i could cross them over around 2khz at -12dB. But, i've read somewhere that it is better to cross somewhere around the beaming point, wich seems to be around 900hz for the hv165xl.
Would that still make any sense to cross around 2khz ?
The tweeters would be placed in the A pillars, about 30-degree off-axis i think....Mid-woofer would be in the bottom of doors, what would be a good orientation for those ?
Considering those options, what would be the best option for sub stage? I just want a single sub in a ported box tuned as low as possible at the rear corner of my dodge Caravan. I want everything to blend in like butter. I would like a good dual-2 around 1200-1500w i would run at 4 ohm at lower wattage...the day i want more output i just wire it at 1 ohm.
i found those,
