good kit under $70?
Type "Kicker CK4" into ebay and go with it. Should be good enough for now unless you wanna upgrade down the road. If you don't wanna use ebay check out http://www.knuconceptz.com for some good stuff at good prices. Best bang for you buck for just kits comes from ebay with the kicker kits though, there are various other kits for 2 amps, or 4 channel instead of 2 channel and so on.
The only thing I would advise with that kit is, trim the 5awg wire to length and use the leftover for a ground wire. It only has 8awg ground wire. All you'll need for that is a couple 4awg lugs.
^^ That right there will sure work on a budget. I had their 8awg kit for quite a while in my car and still got most of it laying around after several installs.
EJGolds
EJGolds
San Francisco Bay Area
Atimm693
