Good dB meter?
They work. The cheap ones barely go past stock system levels and are not accurate. The good ones measure pressure.
Well I guess I'm not getting an accurate reading then... lol
What do you think I'm gettin with this setup?:
AB TNT 15''
Rockford Fosgate R1200-1D
Box is roughly 5-6 cb. ft. tuned to 28hz
Box: Width- 38'' Length- 20'' Height- 22''
Port: Width- 4'' Length- (roughly) 40'' Height- 20"
AB TNT 15''
120-145
Because they can.
From our end (SSA), there was a tremendous amount of work that went into the software design on multiple platforms (Apple, Android, Windows). Not to mention these are small production amounts, so that means it is very expensive to make. So it is not because we can, it is because we have to a set price to be able to keep it in production and be able to afford the constant maintenance of the software (which all updates are free by the way).
APM-2 Wireless SPL Meter - SSA STORE
For being calibrated to the termlab, Bluetooth (no wires), small and portable (pocket sized), free software and free updates, AND the Basscam (only one one the market) feature, it is very reasonably priced.
$400 isn't bad at all for that. I'll end up with one eventually.
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Zackster
Zackster
Alabama
JohnKuthe
    May 24, 2024
