Good 750w RMS @ 2 ohm amps?
I would get a kicker zx750 if you can get a reasonable price on it. The only downside is that it isn't 1 ohm stable so that reduces your options if you want to change sub(s)
Is the tn1.1200 a reliable amp? Its specs look great and price is affordable. How is it compared to the 750.1 and other amps mentioned in this thread? I just don't want to have to worry about overheating (even in hot weather)
Soundstream TN family of amplifiers have the same board as PPI Phantom Class D amplifiers. The black PPI Phantom amps have been out for a while and had become a sort of class leader among "budget amps" (amps sold for $200-230, there is even a 600watt 2-channel you can buy for like $150). The 4-channel version was reviewed by pasmag and confirmed to provide the rated power. I can imagine that given this a budget product, there could be a one off DOA amp now and then, but I don't think there have been many complaints about them. These are probably not the most sophisticated and impecable, but for the money I can't complain. The thing I like most is that they run so cool. If I put a gym bag next to my MB Quart REF4 (class A/B) amplifier, it may as well overheat and shutdown even though it runs at 4ohms and two channels are powering Hybrid Audio Imagine tweeters, that can run on 5 watts of power. The PPI having practically no air flow around it, never gets hot (granted, I only use half of the rated power).
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
941
akillj
akillj
CA
zako
    May 18, 2024
    May 18, 2024
