Good 50 hz song
volume has nothing to do with the frequency
the only time you need to set gain at a specific frequency is if you have some sort of equalization going on, such as a bass boost, in which case the eq needs to be on, set to how you're going to use it, and the gains set at the PEAK frequency
the only other POSSIBLE factor in a slight clip at freqencies lower than the one you set your gain at, is that impedance tends to drop the lower the frequency
Steven206Seattl
Steven206Seattl
Seattle, Wa
coolahan
