going from 15" L5 to 2 12" L7's
tsupra98
right now i have my 15" L5 in a box thats 5 cu ft and tuned to 32 hz. but i just ordered 2 12" L7's and i was wondering if i could use the same box just replace the part of the board that i've cut or put another board on top of it and cut it for the 2 12's?
yea 5cu ft is about right for 12 l7's if thats after port and sub displacement
i know it's after port displacement but i'm not 100% sure if it was sub dis to. i need to check it. and after adding another sub in it it will shrink it a little more. also it's tuned to 32 hz right now is that still going to be good for the L7's?
yea i have my box around 33hz is 5.2net after all displacement
the displacement of another sub wont make much difference on the tunning since u r going from one 15 to 2 12's
but if you wanted you could add another 15 to that box and make it a lil bigger and it would be really loud
thats what i wanted to do in the first place but thats all the space i have. thats why i went with 2 12" instead of 2 15".
yea if u could squeeze another 1-1.5cuft u could run another 15
i wish i could but it's in an acura integra and 5 cu ft is the max i can get. i could get a little bit more if i built the box into the trunk but i still want to be able to get the box in and out of the trunk incase i need the space for something
havent metered it yetwat amp are u running
well for now it's just going to be off my zx750.1 but hopefully that wont be for to long. i plan on getting a zx1500.1 to run them with. right now with the 1 15" i'm hitting 140.8 on the dash and 141.5 in pass kick panel. i could hit a little betting if i tuned a box alot higher but the comps are pretty much over here so i'm not going to worry about it untill next year
sou r hitting that on just that amp
wat kind of car do u have the box in and how is it pointed
and for a long time i was running that zx850.4 on the subs giving each one 425rms
it's a acure in integra and sub and port are both firing up it's a square port tuned to 32 hz.
tsupra98
tsupra98
waco, tx
tsupra98
