goes to the
hydroshocker
Just installed a dvd/cd touch screen double din in honda accord 02. Looks great! lmao BUT now the dash lights dont work correctly....i have a wire called dim lights...or somethinging like that...and a red wire that goes nowhere...stereo is on and playing fine but cant see gauges or if i touch the dim lights wire on a power wire yellow then another lite turns on then if i touch it on the other power wire thqats not constant it shows the other lights on instead(gauges) with the car's head lights on the lights are off and with them off some are on. ITS SO CONFUSING! after i get that fixed...if i can then where the heck do i put the wire that says brake for watching video when in park???//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I dont know about the first problem but the question about the brake wire I can answer. Depending on what kind of unit you have you should just have to ground that wire. But if it is switched on by a sequence you have to hook it up to a switch and run the wire to the switch and then ground the other prong of the switch. (sorry for long answer)
lol...the liight dim wire should be hooked to the light dim wire on the harness i hope you used. if not use a meter and test for the factroy dimmer wire. if you gauges are off look at your fuses you blew one.
the brake wire whould be grounded or hooked to a switch.
hydroshocker
hydroshocker
illinois
FenixAudio
