give me some input.... (not hardware related)
cappy72
NY
so I had a choice.... either glass the doors right off the bat or install them into the sides of the door, about the same area as my hip.
I was thinking about getting a 4 inch driver in to the factory spot so I get a 3 way setup.
Thought?
now that you have that hole...I'd glass the bottom of the door and keep your drivers closer to the front. Maybe using the space that you made for a sealed/ported area for midbass?
welcome back, btw.
Horrible, Horrible location.
Even if you go with a 4" driver to go in the factory locations, that's still very poor placement of that midbass driver you have installed at the rear of the door.
If you want to go 3-way, 'glass the smaller components (4" midrange and tweeter) into the kicks and mount that midbass driver in the factory locations.
1 problem is that I can make kicks, the area is too small
So if I wanted to install a 3 way setup it would have to be in the doors.
I was planning on running the 6.5 from ~80-1000 and the 4inch from 500 - ~4k
cappy72
cappy72
NY
Ignatowski
