******geo Metro Wall Build ******
Yeah man that thing is nuts am starting my upgrade for this season looking for a second sub or motor and basket to go with the 18in PSI platform 2 I am having Hispls build for me gonna run a pair in my 2 door explorer in a wall
Whats the car tuned to and what was the best score you got at an event?
I've got a 1994 GEO METRO with a wall as well, but I've got 2 - 15's and a single battery that's under the hood.. Haven't really decided on amps, although I've put one STETSOM 7k2d at 0.5 ohm and did a 153 legit sealed on the dash, mine is tuned high 50hz +
I've read this thread and it's awesome, maybe if I change vehicles for competition I'll drop the box down to 25hz
Did you get the roof fixed.
the enclosure is tuned to ~30hz. best score is right at 159 at 41hz (door open mic on dash) with the two crescendo bc5500 amps.
this was a score log from a test run before we added all the extra batteries.
154.5@25hz
155.9@27hz
156.5@28hz
156.7@29hz
156.7@30hz
156.8@31hz
156.8@37hz
157.5@40hz
158.2@40hz
158.4@41hz
158.4@42hz
just to give an idea of bandwidth.
and yes, after the last roof upgrade there have been no more issues as far as that goes.
but now the door skin is ripping,
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
891
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
JBLCAMRY
KCB
JBLCAMRY
239, Florida
BoomTaco64
    May 20, 2024
    May 20, 2024
