Sold Fusion FCA-4000D Surfboard Amps
AudioXtremes
Team FatStig
As you probably have seen I have been sort of liquidating all my stuff so these must go now that I am running Sundown amps. While these are gobs more power than a SAZ3000D they don't strap. Now to the info.
Link to Fusion product information site.
Tested by team fusion.
This amp has had extensive testing and will do loads of power. On a solidly backed electrical system over 4000 watts can be expected at 1ohm.
Test on a single battery.
Fusion 4000D
3536 watts RMS measured
588 Amp Current draw
amp wired at 0.7 ohms running 1.9 ohms with box rise.
Output: 80.0 VAC and 44.2 Amps
Voltage Drop under load 14.4 – 11.3 VDC
Test on a 18V bank of batteries.
The measured output at 0.3 ohms DCR:
90 VAC – 89.6 Amps
1.0 ohms w/ box rise
8064 watts
This amp will run daily at 0.5ohm no problems. Burping at .3ohm is no sweat also. I have 2 of these. Now on to pics.
Not my pic...
I am looking to get $650 shipped and insured each on these. They do the power. Both are 8/10 cosmetically and 10/10 functionally. The cases they come in are a little worse for wear though.
AudioXtremes
Team FatStig
AudioXtremes
Indianapolis, IN
AudioXtremes
