Sold Fusion FCA-4000D Surfboard Amps
AudioXtremes
Team FatStig
As you probably have seen I have been sort of liquidating all my stuff so these must go now that I am running Sundown amps. While these are gobs more power than a SAZ3000D they don't strap. Now to the info.
Link to Fusion product information site.
Tested by team fusion.
This amp has had extensive testing and will do loads of power. On a solidly backed electrical system over 4000 watts can be expected at 1ohm.
Test on a single battery.
Fusion 4000D
3536 watts RMS measured
588 Amp Current draw
amp wired at 0.7 ohms running 1.9 ohms with box rise.
Output: 80.0 VAC and 44.2 Amps
Voltage Drop under load 14.4 – 11.3 VDC
Test on a 18V bank of batteries.
The measured output at 0.3 ohms DCR:
90 VAC – 89.6 Amps
1.0 ohms w/ box rise
8064 watts
This amp will run daily at 0.5ohm no problems. Burping at .3ohm is no sweat also. I have 2 of these. Now on to pics.
Not my pic...
I am looking to get $650 shipped and insured each on these. They do the power. Both are 8/10 cosmetically and 10/10 functionally. The cases they come in are a little worse for wear though.
you can do much better than L7's for the money. but I would start a different thread for that if I were you, this could be considered thread jacking;)
My apologies just wanted to know what ohm i could get 4 subs to do on this amp. But anyways what kind of electrical setup would I need for this amp to do a little over 4000 rms
no problem here, I would think at the very least you would need some rather large Kinetik's or similar, definately the big three, and I would keep taking lunch to work so you can save for an alt.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif but the batts would do for now.
I'd figure at a minimum a pair of Kinetik 2400s per amp. With that kind of voltage you'll be pretty much good to go //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
These are CRAZY AMPS!!!! I had one of these in a Rex on 2 Shocker Sig 15" with 4-8volt batts and I was doing 155+ with out a good alt. That was with only 2 days of tuning so I know these amps are crazy. Bump for awesome amps and a great guy thats selling them.
AudioXtremes
Team FatStig
AudioXtremes
Indianapolis, IN
AudioXtremes
