Fusion amps, and cheap power Q's
netzero
USMC
Hey is Fusion car audio alright stuff? I've seen some people use their stuff, but how are their amps? I need like 225-250 RMS @ 2ohms and they have an amp for like $100 that does that. I have the choice between that or an orion Hcca-d600 which does that same.
First Q: Are fusion amps OK
Second: Between Fusion, orion, or infinity Reference 311A , which one for $100, or suggest a cheaper alternative to power two little 8s
Thanks!
What Orion amp?
orion Hcca-d600 = $100
4 Ohms: 125 watts x 1 chan. RMS
2 Ohms: 225 watts x 1 chan. RMS
1 Ohm: 300 watts x 1 chan. RMS
or
fusion EN-AM60010 = $90
170 Watts RMS x1 Channel @ 4 ohms
250 Watts RMS x1 Channel @ 2 ohms
I need 200~250 so either will work, but the fusion is more watts and cheaper. This is for a little setup in the house so im not looking for the best. But wish one will be the best bang for the buck?
well I personally Have never used either of those amps, but my experiance with Orion has been awesome so far. The fusion is a little over rated probably, as the orion most likely does rated.
You think i should just pay the extra $10 and get the orion? It's not that big of a deal, I just want sure if the fusion would do the rated power, and be a few buck cheaper.
iam running a fusion nv-am2500 in my olds right now. its rated at 1800rms at 1ohm and benched at over 2k. its a very big amp though. imo from using this one iam very happy with it. here shortly it will be on a dd 3510 at 1 ohm.
orion Hcca-d600 = $1004 Ohms: 125 watts x 1 chan. RMS
or
Fusion is okay... but it's not really reliable vs. Orion.
Orion all day.
Iv seen a few people do pretty well with fusion, but like thevic24 said, it was mostly higher end stuff. I'll probably end up getting the orion. It's rated for 1 Ohm as well, so it'll give me more options later.
netzero
USMC
netzero
Columbia, SC
netzero
