fusing
alright im pulling 652 amperes off of my amps im running 3 amps will running 0 gauge from the battery to a distro block of 3 4 gauge wires witha 300 amp fuse be enough?
652 //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif what amps u running?
I didn't get that deep but yes, definitely so. I just assumed that he would be taking those precautions if hes using 3 2500 watt amps. But you know what assuming does //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
With those amps hes probably pulling 300ish, I dont know the amp at all some i may be high on that figure. But I would also assume they are fused with 120-150 amps worth of fuses
Each amp is fused with 2x60A fuses and theyre only 1500RMS. If I were him, I'd invest in an new alt...
btlking
Registered User
btlking
Uranus
j3bus2k3
