Papermaker85
Banned
I want to post this for everyone to read and understand a-little bit about fusing and the purpose of fusing and the real Trick to getting great output on higher powered systems.
First I want to say that I am a Certified Electrical and Instrumentation Technician. Make no mistake that these recommendation come for the NEC(National Electrical Code) and have been continuously researched for over 40 years.
Without getting into to much detail when you fuse you are A) protecting the wiring B) the device and the wiring.
That being said if you so choose to protect the device from Over-current you MUST A) use a wire rated to carry at least 125% of the total loads maximum current draw.. This IS VERY important
For example your common 2000 watts class D amp. Well designed and well built at maximum current consumption may be 290 amp @ 12.5 volts(always use the lowest voltage because chances are you voltage under a very heavy load will drop past 12.5) so 290x1.25=363 amps.
In that case Id suggest running one run of 4/0 and fusing 80% of maximum load ruffle 290 amps. Why? Because fuses by design will carry 100% of there load for several minutes. Under protection circumstances you want to fuse to provide adequate power but to blow before the power supply smokes. That being said the inconsistency of the fuses may require a=little more or less but its a starting point and without testing each fuse its impossible to really tell.
Remember 290 amps is still enough for the 2000 watts output continuously so its no issue under normal operating conditions even under moderate clipping you' re fine!
In the case you simply want to fuse the wire you simple choose the appropriate wire for the current draw.
This is a list of ampacity of wire. NOTICE that they have temperature ratings! These rating are based on the conductivity on the conductor the heat dissipation of the insulators and the type of installation the wire will be used in!
Most car audio wire is good wire. Don't be fooled by the claims of "over sized 1/0" its called 1/0 for a reason. Even though its larger is DOES NOT HANDLE more current. Wire is rated by "circular mil" if it says 1/0 its 1/0 granter they aren't lying about the actual surface area of the conductor.
HOW to figure what wire I need?
The manufacturer listed "recommended fusing" its pretty safe bet to follow it. So 200 amps. You want a wire that can handle 200 125% 250 amp. This gives you adequate head room and ensures VERY LITTLE VOLTAGE DROP.
Here is a link to a list of conductor ampacity and recommend fusing for said wire.
Wire Size Chart for Conductors in Free Air
A final though and real world testing. Most 2000 watt amps under normal conditions on a reactive load will never see its resting resistance. Impedance fluctuates with AC current and as heat builds up resistance rises.
What does this mean? Lets say you have a dual 2 ohm woofer, you wire it parallel of course to get one on NOMINAL.
You resting ohm should be 1-ohm. When you pass a varying signal like Ac(what speakers play) that rises. Typically between 1/2 the loads ohm up to 3x the load in the.
So your not getting close to the 2000 watts //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif At best you may get 1000 to 1500 watts so in reality you are drawing only around 150 160 amps instead of the 220 to 240 amps. That's pretty much worst case scenario so your wiring is PLENTY big.
That bring said don't try to down size your wire because your not getting the full 2000. Its foolish and hurts output and lower reliability on the gear from heat and voltage drop. You pay good money for a good amp DON'T buy undersized wire..
