Fuses keep blowing
2Fast2Charles
Too Fast Fo' Ya!
OK So the 4 fuses in my ED Nine.1 are blown. so i go to replace them. unhook ground from battery. then i put the fuses in. go to put ground back in and its sparking as i connect it to the battery i was like //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
turn the car on and it sorta stutters then the 4 fuses blow AGAIN.
sooo can someone help me in on this? much appreciated. thanks.
how's about you disconect the neg. term from the batt then you're speakers from the amp allso. now put you;re fuses in ...then reconect the batt neg... if they blow again w/ nothing hooked up other then you're + - & rem. wire then you're amp is more then likley BLOWED UP BRO!!
//content.invisioncic.com/y282845/emoticons/imwithstupid.gif.ff72b14418b3c35ebdf1ccd38da21695.gif Plus whenever you are installing/removing an amplifier you should either disconnect your battery or remove the inline fuses from the power wire to keep everything from sparking and possibly ruining something.
yea, somewhere your power wire is grounding out...check all the connections, look for cut shielding and loose strands of wires
The fuses in his amp are blowing, not the power wire.
Alright well I'll go buy new fuses tomorrow. I looked for any cuts or anything in my power wire and couldn't find any. so i guess ill try disconnecting my sub then trying again //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I would try to disconnect the battery terminals then all the speaker terminals on the amp, replace the fuses in the amp, reconnect the battery terminals then the speaker terminals to the amp, if you still have a problem try tracing your power and your ground from the amp and make sure you have not either burnt it or if you have any nicks or cuts in it.
2Fast2Charles
Too Fast Fo' Ya!
2Fast2Charles
Tucson, AZ
spin dB
