Fully Complete!
Kimb0
after a few weeks of hard work i finally completed my car audio sytem alone i might add //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Speakers on all 4 doors look identical to this MTX Thunder THS602 260w 65rms
Amp mounted under the Floor Sony Xplod SMSD-14X 600w
MonoBloc Mounted under compartment bay Pioneer GM-7200M 800w 360rms
The setup from far back, bay compartments all open
The setup from far back, bay compartments all Closed
Sony Xplod 1300w Subs 4ohm
Cheers hope yall' like it comment me! :p
well you see the compartment where the shotty xplod amp is has a air hole a large one to leading to the exterior where the bumper is and thr is holes leading into where the monobloc is so its all good...i hope.....
that pioneer is upside down when that door is shut correct? if so that is trouble. shouldn't mount an amp upside down, especially in such a small area
shite really i cant see it being a problem but then agin you have a forum ***** tag so i must listen! anything else you can see wrong ? :p
also wires will wear thru and cause shorts eventually if they can move, might wanto tape them down or use grommets to avoid future fires!
amps dissipate heat through the heat sink. heat in general rises, so when said amp is upside down, the heat that gets dissipated will rise back into the amp, and the amp will never cool, then on top of that you only have a couple inches for the heat to escape so basically you are trapping heat around your amp
good point...umm its only been running a few short days like that so damage will be minimal i guess ill have ot find a new spot for it, thanks for the heads up. ill make sure i cable tie down the cables aswell... incase or large car fires!
thats the way i was told my a mate to set it up ?
run the RCAs from the Hu to the Monobloc and use the high level output from the Hu and connected it to the high level input to the amp seems to be working a treat everythings in working order or have i done it wrong?
yeah everythhing is fused and everything is also grounded very well i made perfect sure of it cos i cant afford to replace all that stuff even tho its only low end T_T subway pays rather low hahaha
the amp was only $200 Aus 4 channel 600w i think it gives 55rms each channel which is under doing my speakers at 65rms but thats okay with me
Kimb0
Kimb0
Australia
Kimb0
