It has black metal cone, and dual 4 ohms.
Will try to make required pics.
As for refs. I am relatively new to car audio stuff, but already not that dumb (I think) in the area. I can give my
ebay user name to check. I had some selling/trading activity on other forums, not audio related, but do not know if it helps.
If the person who I will be trading with has good refs, I can ship first and wait the moment it arrives to recipient.
Here is the info from vendor site
http://www.tcsounds.com/tc9.htm)
Key Features
• 140 Newtons2/watt Motor Force
• 800 Watts Continuous Power
• 3" Anodized Copper Voice Coil
• Single Dish Aluminum Cone
• 1" NBR Surround
• 145 Ounce Magnet Structure
• 18mm XMax
• 8.0" Diameter Suspension System
• Cast Aluminum Frame
Advanced FEA Motor System
• Double stacked 3/4" tall ferrite magnets and bored T-yoke for long throw
• 145oz top grade magnet structure
• Low carbon steel used for the gap plate and t-yoke
• Pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
• High excursion 8.0" linear roll poly-cotton spider
• Intergraded woven leads to prevent lead-slap
• 3" diameter, 4-layer copper wire voice coil with an anodized aluminum former
• Dual 3.0Ω (4 ohm nominal) voice coil configuration
• Lightweight brushed and powder coated aluminum cone
• 1" wide long throw, highly durable NBR surround
• High quality thermal flexible epoxies to ensure longevity
Performance
• Effective motor force of 140 Newtons2 per watt (BL2/Re)
• 800 watts continuous power (2400 watts peak)
• 18mm BL XMax (voice coil, one-way)
• 37mm XMech (mechanically limited, one-way)
12" TC-9
Qts 0.354
Qes 0.384
Qms 4.46
Fs 27hz
Res 5.96Ω
Ls 4.35mH
Lp 8.26mH
Rp 10.88Ω
Dia 250mm
Vas 35.3l
mms 331g
cms 104um/N
bl 29.2T*m
Spl 84.7dB
