Sold FS: Zed Built Nakamichis...
Sweet amps, I hate how ZED only put two inputs on the 6 channels, Us acoustics 6300 is the same way...
Won't matter for most people, but I wanted to run a 3 way active front stage //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Good luck!
Good luck!
I wanted to as well...same concept...
btw;
I know I am suppose to post prices, but in this case I really can't...
I need the money ASAP...and I just can't wait for people to make offers...and bs me around...
But for the sake of arguement...
$400 for the PA-506, $300 for the PA-1002 in excellent condition, & $150 for the OK condition one...
Thanks
Actually, I just looked at the auctions, and you are a REAL scumbag...
You buy a known bad amp, then try to pass it off on eBay as a "I don't know if it is good or not" amplifier...
You go on other boards saying how you are a junior amp repairman, and then on here and ebay try to play it off as a 'unknown' amp with an as-is auction...
Flat out fricken scam artist scumbag, just like I always thought... Go rot you retard... //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
I called you out on DIYMA about trying to sell amps you repaired yourself, and you tried being all high and mighty about it... Now you put up an auction and say you don't know the condition when you **** well know you can't repair it and it is blown... Is this the one that took out someones headunit??? I bet it is...
Scumbags like you need to be banned from selling... //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Hmmm, your still on this...
First off, I took the amp to my school to have it powered up...just connected a simple 20a 12v DC PSU & 10a 12v PSU to the amp...
Using a signal generator, I pushed a normal 100hz 2v signal through the amp.... I got an output...
I never connected it to my car/subs...so I could not confirm its full operation...
I sat for 2 hours and examined the amp guts...comparing it to my other amp with a magnifying glass...
I discovered nothing...
I do not have subs to connect this amp too...was I suppose to spend the money to purchase subs....to test an amp?
That would have been pretty stupid...
I have also compensated my buyer with other items...
I have dealt with many members here and on ebay...I don't **** around when it comes to money...
Yeah right, you are a scamming piece of $hit...
There is no two ways around it, you just admitted that you 'tested' the amp to your inadequate abilities and basically flat out lied to the eBay members that you 'could not test it'...
You just STATED that you TRIED to test it, which is total BS...
You know for FACT it is a F-U-C-K-E-D amp... PERIOD... End of Subject...
I am CERTAIN you have subs, did you hook them up???
Did you hook up one of your headunits???
Of course not, BECAUSE YOU KNOW IT IS A F-U-C-K-E-D amp!!!
You know for FACT that you would have blown a sub in the least, and a headunit in the worst...
You lied, you scam, you are a PIECE-OF-$HIT... End of subject....
I guess I need to quote your stupidity so that it is here for posterity, as I am sure you will edit your post because you know you F-ed up...
As promised... EXACTLY as you posted it...
Die SCUMBAG!!!
mavster
mavster
New York, NY
SlainNothing
