Sold FS: Zapco Studio 300
Zackdp
i have a zapco studio 300 that has been sitting underneath my bed for some time now and i think its time we part ways. this is VINTAGE zapco and was designed by Robert Zeff himself before he left Zapco.....
Specifications:
Output Power: 150 watts/ch @ 4ohms, 20Hz-20kHz
Output Power: 230 watts/ch @ 2ohms, 20Hz-20kHz
Mono Output Power: 460 watts/ch @ 4ohms, 20Hz-20kHz
T.H.D. + Noise:
T.H.D. + Noise:
S/N Ratio: > 105dB
Dynamic Headroom: .6dB @ 2 ohm load
Separation: > 700 @ 4 ohms, 350 @ 2 ohms
Damping Factor: > 700 @ 4 ohms, 350 @ 2 ohms
Input Type: Fully balanced differential REF GND
Input Sensitivity: .25 - 5.0 Volts, variable
Maximum Input Level: 10 Volts R.M.S.
Input Impedance: 20K ohms
Crossover Range: 30Hz - 720Hz
Crossover Slope: Low Pass 12dB, 24dB/octave
Crossover Slope: Hi Pass 12dB/octave
Hi Pass T.H.D. + Noise:
Hi Pass Separation: > 85dB
Hi Pass S/N Ratio: > 120dB
Maximum Output Level: 10 Volts R.M.S.
Power Requirements: 60 Amperes max. @ 2 ohms
Fuse Rating: Dual 20 Amperes - Automotive blade type
Minimum Load: 2 ohms stereo
Idle Current: 1.6 Amperes
Dimensions: 16" L x 5-7/8" W x 2-1/2" H
as you guys know this is zapco, old school zapco and produces more then rated output, notice the rating is across the full frequency range and not your typical 60hz test....
300$
taking offers....
also amp was recently sent in to zapco for repair and has had all brand new rca connectors - speaker terminal's yadayadayada.
Zackdp
Zackdp
Modesto, Cali
sinosic
