Fs Vs Fr
nismos14
Looking at some subs and here are my questions:
Listed FR is 10hz-400hz the FS was somewhere in the 40hz range.
Can someone explain to me why the FS is so much higher than the lowest part of the FR? I always thought the FS was relatively close to the lowest part of the FR.....
How does this particular drivers parameters affect performance?
Fs does NOT tell you the lowest frequency that the driver will PLAY. It tells you the Free Air Resonance of the driver. FR is Frequency Response, and is thus a rating for frequencies the driver can play.
Sometimes they specify tolerances (i.e. +/-3dB) as well. Sometimes these are fairly honest, and sometimes they are not at all honest. You have to bear in mind Fs is a DRIVER parameter, and realistically FR is a SYSTEM parameter (driver + enclosure + environment) and thus the two often will vary considerably, even if both are being given honestly.
So in this particular driver, I can expect a different FR based on application (obviously) but if I were to utilize this driver as an IB driver how does the FS affect that? Can I expect the driver to produce good output below the FS?
Yes, it will most likely go well below Fs in an IB application. In car applications, most drivers in an IB configuration shouldn't have any trouble going below 20Hz, even with an Fs in the 30s.
Hey thanks man. On a side note, I used to go to Des Moines all the time when I lived in IA. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
nismos14
nismos14
Jersey
nismos14
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
