Id like to get $50 for these
They have been used and powered, but not abused.
They get quite loud for fabric tweeters, definety great for people who like LOUD treble.
I crossed these over at 1.2khz at a 18dB slope, but you can bump them up higher if you like with a less agressive slope.
Here's some specs off madisound
Dual Concentric Textile Ring Dome
Neodymium magnet
Phase Plug
Ring formed absorption chamber
Heat sink
Gasket
4 Ohm
Fs 950
92.5dB
Outside diameter 65mm
Cut out 46.2mm (47mm max!!!)
Depth 21mm
This one does have a slight dimple in the cone, it does not affect the performance at all. The other is perfect.
The flange does twist off and you basically have a 1.8" tweeter that fits just about anywhere.
Neodymium magnet
Phase Plug
Heat sink
Gasket
4 Ohm
Fs 950
92.5dB
Depth 21mm
