I was going to use these for my next setup but I doubt I'll do anything with them anytime soon. I got these direct from US amps factory fresh back in October. These are the 06' model NOT the 05'. They totally remodeled the internals for 06 on all the MERLIN line. As you can see I customized them with a plexi window. Nothing was modded to the amp. They were never powered or installed. They come with all paper work exact how I recieved them.
Asking $290 for the MD1D and $270 for the MD42 shipped!
These are CEA compliant in power and specs!
MD42
Power: 75wx4 @ 4 115wx4 @ 2 250wx2 @ 4
S/N Ratio: 100dB
THD: >.03%
Freq Response: 10hz-30khz
Channel Separation: 83dB
Damping Factor (@14.4v): 400
Crossover: HP 65hz-1khz LP 40hz-250khz Subsonic: 15-40hz
Protection: thermal, overload, short circuit, dc off-set
Fuse Rating: 30A x 2
Voltage Range: 12v-16v
Size (WxHxL): 2.4" x 9.0" x 17.7"
MD 1D
Power: 300wx1 @ 4 600wx1 @ 2 1200wx1 @ 1
S/N Ratio: 80db
THD: >.09% (this is not a BS number like the majority of the companies put out. this is the actual THD)
Freq Response: 20hz-250khz
Channel Separation: N/A
Damping Factor (@14.4v): 100
Crossover: LP 40hz-250khz Subsonic: 15-40hz
Fuse Rating: 30A x 3
Size (WxHxL): 2.4" x 9.0" x 19.6"
MD42
S/N Ratio: 100dB
THD: >.03%
MD 1D
S/N Ratio: 80db
