Sold FS: Tons 'O 10s" & Enclosures: RD 10s", Ported & Deathbox
528hz
Everything'sMiscellaneous
Back with some deals gentelmen!
I have a total of 7 subs, and 2 enclosures I'd like to get rid of at the moment. All prices are pretty firm I "may" entertain trades for 3 12s". All items are cosmetically/mechnaically excellent.
First up I have two RD Sonance 10s", DUAL 2 OHM subs. They are brand new, never seen power and are the V3 versions. They are also flatwinds and can take up to 1200 watts RMS. Specs can be found here: Top quality audio equipment: Revolution Design Audio
$150 SHIPPED. 1 SOLD, 1 left
Next I have 2 RD Sonance 10", DUAL 4 OHM subs. They are all used, but in excellent mechanical/cosmetic condition. The only thing I did to them was paint some epoxy around the dust caps to insure that they stayed, and they aren't going anywhere. I didn't have my small drill with me at the time of taking the pics to take them out of the bandpass. Specs can be found here: Top quality audio equipment: Revolution Design Audio
ALL Dual 4 ohm 10" Sonances have been SOLD!!!
Thirdly, I have an RD Classic 10" Dual 4 ohm and a Deware Deathbox. That's right...a Deathbox. if you're not familiar with this enclosure you can go here and find out about it: DECWARE's Death Box II - High Output Subwoofer
The Classic 10" is brand new and never seen power. Specs can be found here: Top quality audio equipment: Revolution Design Audio
I've run a Sonance in the Deathbox to test it out and it's really amazing! Gets about as loud as 2 ported 10s" off very little power. I was running my Stetsom 4k2d at 8 ohms and it pounded. It has a fully adjustable port to set the desired tuning frequency. Dimensions of the box are: 13 7/8 x 19 1/2 x 13 7/8.
RD Classic 10" and Deathbox have been SOLD!
Finally...I've had this ported box for two 10s" for quite sometime. Need to get it out of here. It was built by SPY and it made out of Birch ply. The box is COMPLETELY KERFED, and yes, I know the staining job looks horrible, but all you need to do is give it a slight sanding and paint it to your desired color. Or for a small fee, I would paint it for you.
It is really a great box. Tuned @ 34 hz, and 2.5 CF after displacement of most 10" subs. Dimensions are: 13 x 20 x 31
SOLD!
RD Sonance D4, it says 500/1000 rms? So are they 500 RMS 1000 Peak or whatever?
Yes the site does say 500 RMS, 1000 Peak, but I personally have run approximately 1000 RMS to each of the Sonances I have have owned, and they can take it without the dust caps even getting warm. RD's subs can take more than they state on the website.
When I ran 4 of them sealed, I actually clamped my Stetsom 4k2d. With a reactive load of 2 ohms, and rising to 4.56, I got 3033 watts of true power. My box was rather large for 4 sealed 12s" at just over 6 cubes total. Typically the larger the box, the higher the rise. Different subs also react differently than others so...
I ran them for over 6 months and they were perfectly fine.
I then ran 3 of them at 2.67 ohms reactive, but never actually clamped it, but my rise should have been slightly less I imagined, since I ran them in a smaller ported box. Therefore I assumed I was getting at least 3000 watts per reference to my first time I clamped my amp.
If you still have the deathbox for sale...please give me the info as to wear to send the money! I will send it via paypal asap, if its still available
The Deathbox is indeed still available. PM me and we will go from there should you choose to want to purchase it.
All dual 4 ohm Sonance subs have been SOLD!
528hz
528hz
In the Space between Space in NM
528hz
