This is a new in the box TC Sounds OEM 10" SVC 4 Ohm subwoofer. It has only been out of the shipping box to be looked at. It's never seen any kind of power, mounted to an enclosure, etc. It looks exactly like the picture below except it has a black crinkle coat finished basket instead of the silver basket.
Features:
- Lightweight Honeycomb glass fiber cone
- 1" tall NBR surround
- 28mm xmax
- 190 ounce motor
- 800 watts RMS
- 3" wide, long-wind AL voice coil
- Dual 8.5" spiders with woven leads
- Single 4 ohm DCR or Dual 4 ohm DCR
- Actual weight: 29.5 pounds
- *NOTE: Actual drivers have BLACK frames (not silver)
Specs:
- Qts 0.357
- Qes 0.400
- Qms 3.35
- Fs 30Hz
- Res 3.11 ohms
- Ls 4.0 mH
- Lp 6.26 mH
- Rp 9.9 ohms
- Dia 208mm
- Vas 19.3 liters
- Mms 224 grams
- Cms 119 um/N
- BL 18.35Tm
- Spl 83.3dB
Enclosure Recoomendations:
- Small Sealed: 0.3 cubic feet
- Large Sealed 0.6 cubic feet
- Ported: 0.5-0.6 cubic feet with a single 10" or 12" PR
Price = $150 shipped.
The easiest way to get in touch with me is through email. Nick@stereointegrity.com. If you PM me on this forum and I don't respond, don't say I didn't warn you. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Features:
- 28mm xmax
- 190 ounce motor
- 800 watts RMS
Specs:
- Qts 0.357
- Qes 0.400
- Qms 3.35
- Fs 30Hz
- Res 3.11 ohms
- Ls 4.0 mH
- Lp 6.26 mH
- Rp 9.9 ohms
- Dia 208mm
- Vas 19.3 liters
- Mms 224 grams
- Cms 119 um/N
- BL 18.35Tm
- Spl 83.3dB
