SOLD FS/T RD Audio D9 5400w
CL1CKCLACK
CarAudio.com Boss
RD Audio D9 Amp
Item Description/Condition:
The Amp is in pristine condition. there isn't a single flaw on it, and it has never been repaired nor ran on low voltage 10/10 cosmetically, 10/10 mechanically
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 guage (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
Specifications
RMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
800+Ship and "Handling" Fees... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Trade For A 2k-3k Amp+Cash
Will Ship Anywhere in the world, at owners cost
Wow apparently you are on crack. You show me a thread that says I scammed someone on CACO with a Sundown amp or anything for that matter. The guy that claims I scammed him over there got his ******* in a bunch because I tried selling the sub he sent to me the same day I got it and people were sending me offers when he didnt get anything. He blew the subs I traded him because he free aired them on half of their rms using a dirty signal from a power supply. Next time you want to start throwing out stupid comments you want to know what you are talking about first?
Phishhead sent me two JL w3s one blown, and both were beat all to hell. described as having a small crack and one mint. no way i blew them their rated 500rms and i free aired them at 150 had them at low volume just to see if they worked. and not dirty signal at all i have installed systems 8 years with not one problem. pm me if you want the link to the CACO thread. but i would suggest everyone stay away from this guy, dude is a liar.
sorry to thread dump your post. ^had to clear that up
Phishhead sent me two JL w3s one blown, and both were beat all to hell. described as having a small crack and one mint. no way i blew them their rated 500rms and i free aired them at 150 had them at low volume just to see if they worked. and not dirty signal at all i have installed systems 8 years with not one problem. pm me if you want the link to the CACO thread. but i would suggest everyone stay away from this guy, dude is a liar.sorry to thread dump your post. ^had to clear that up
It's all good I already knew he was a POS.
A Link would be very helpful. Id be interested in taking a look at some gear
183
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
296
CL1CKCLACK
CarAudio.com Boss
CL1CKCLACK
Land Of The Hicks...
Ge_off_me
