Sold FS/T dc Level 4 15" d2
allout13
Im looking to get $200 plus shipping. has a small rough spot on the surround thats only noticeable if you rub your hand across it. This sub is good for 1500 watts daily. The only reason I am getting rid of it is because I have 3000+ watts that I hardly get to use. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif pics will be up in a little bit. anything else you want to know, just ask.
only trades I would be looking for is a 12" or 15" sub that can be wired to 1 ohm and that will take 3000 watts daily
info from their website
The Level 4 sub was designed to make people angry. With sick amounts of output, it’s hard to beat!
The Level 4 sub is a large double stacked motor weighing in at almost 30LBS each, wrapped in a magnet boot with a chrome top plate and T yoke yielding 23.5mm of X-Max
You also get with the upgraded progressive spiders, cone, surround, 3" coil, cast basket, push terminals and upgraded lead wire.
The Level 4 is rated at 1000w RMS and 2000w peak.
Designed for ported enclosures and is a great choice for
high-powered daily systems and competitors.
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8”OD semi cup progressive roll spider
• Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 2 ohm 3” Hi-temp Aluminum voice coil wound on black
anodized voice coil former
• Rubber magnet cover
more specs here http://dcsoundlab.com/specs.html
you are 2400 miles away from me //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I could see what shipping would cost if you would like and I could cut you a little slack
allout13
allout13
Georgia
whitedragon551
