FS: Sundown SAZ-2000D
undeadxsunshine
what it is
Sundown SAZ-2000D
Good working condition. Cosmetic condition is not perfect. This amp ran 2 SA-12s @ 1 ohm for the past 5 years in my Tribute with no problems at all. Had to get rid of the vehicle so I'm selling the system, will be doing something different in my new Wrangler.
RMS power, 2 ohm linkable/dual mono 4000W x 1CH
RMS power, 1 ohm mono 2000W x 1CH
RMS power, 2 ohm mono 1000W x 1CH
RMS power, 4 ohm mono 500W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 200A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 494(L)mm
Digital Class-D Linkable Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stability
Daisy-Chain Through Output RCA
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
RCA Line Input and Master Output
24dB Octave Crossover Slope
24dB Octave Variable Subsonic Crossover Slope
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Wired Remote Controller
MSRP $899 USD
$400 + shipping OBO
You pay shipping. I usually ship UPS but will use other carrier if buyer desires.
undeadxsunshine
what it is
undeadxsunshine
York, PA
undeadxsunshine
