Sold FS: Sundown SAX100.4
Qbenjamin
This amp is brand new in the box. I received it in a deal from Jacob. I need another Belle, so this amp has to go. Specs are as follows:
The SAX-100.4 is the second "X" series multi-channel amplifier to come from Sundown Audio. This model is built to the same exacting standards as the SAX-100.2 but adds another set of channels and more advanced crossovers. It's flexible crossovers allow the user to run a 2-way active speaker setup with no external processing. It packs enough punch that one could also run a set of front speakers with one pair of channels and a subwoofer, bridged, on the other pair of channels for use as a total system amplifier where high power is not required.
SPECIFICATIONS:
100 x 4 watts @ 4 ohms
160 x 4 watts @ 2 ohms
320 x 2 watts @ 4 ohms bridged
Damping Factor > 200 @ 4 Ohms
0.2v - 6v adjustable input sensitivity
10 Hz - 40,000 Hz Frequency Response
Channel Separations: 75 dB
> 90 dB S/N Ratio
4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
Selectable HP / LP / FULL crossover
CH 1 & 2 Variable HP crossover 50 - 5000 Hz @ 12 dB
CH 1 & 2 Variable LP crossover 50 - 500 Hz @ 12 dB
CH 3 & 4 Variable HP crossover 50 - 500 Hz @ 12 dB
CH 3 & 4 Variable LP crossover 50 - 5000 Hz @ 12 dB
10 Hz - 500 Hz variable subsonic filter (CH 1&2 and CH 3&4)
Subsonic filter allows for band-passed crossover configuration
0 - 18 dB adjustable bass boost
35 - 120 Hz Variable Bass Boost Center Frequency
Wired Remote Control unit included
3x 30 Amp Internal Fuses
16.5" L x 9.9" W x 2" H
$449 US Dollars - MSRP
$495 Canadian Dollars - MSRP
$449 Euros - MSRP
Pics can be found here:
http://sundownaudio.com/pp1004.html
$269+shipping
gaypal fees are extra if you choose to use it. Postal money orders are accepted.
Qbenjamin
Qbenjamin
Braavos
Qbenjamin
