Sold FS: Sundown SAX-100.4
bose301s
I can break these cuffs
Sundown SAX-100.4d
I got this in June for trading in my SAX-100.2 It is in great shape, a few light scratches but nothing terribly noticeable, 9/10 cosmetic, 10/10 functionally.
The SAX-100.4 is built to the same exacting standards as the SAX-125.2 but adds another set of channels and more advanced crossovers. It's flexible crossovers allow the user to run a 2-way active speaker setup with no external processing. It packs enough punch that one could also run a set of front speakers with one pair of channels and a subwoofer, bridged, on the other pair of channels for use as a total system amplifier where high power is not required.
The latest "D" revision features industry leading crossover flexibility even more advanced than prior versions and also features and upgraded power supply section for more power and enhanced longevity.
SPECIFICATIONS:
* 4/3/2 Channel Bridgeable Class-AB Amplifier
* MOSFET PWM Power Supply
* Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
* Variable Subsonic Filter
* Independent 1/2 and 3/4 Channel High Pass Filter Variable
* with x 10 Range Selectable Switch
* Independent 1/2 and 3/4 Channel Low Pass Filter Variable
* HPF/FULL/LPF Selectable Switch
* Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
* Switch with 12dB and 24dB Octave
* Variable Input Level Control
* Input Sensitivity : 200mV ~ 6V
* Subsonic Filter : 10Hz ~ 500Hz
* Signal Input and Line Out RCA Connectors
* Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
* Tested Voltage & THD: 14.4V & Less than 0.05% THD
* Operating Voltage : DC10V~16V Power Input
* Wired Remote Controller
* MSPR $549 USD
$275 shipped
when you say you traded your sax 100.2 for it, do you mean you traded with someone on these forums?
did you get the SAX 100.4 new or used or refurbished?
accepting any trades? what setup did you have the sax 100.4 running?
I traded it in using Jacob's trade in program. It was a new amp in June. Only trades I am looking for are an M-Audio MobilePre USB or a Behringer DCX2496.
I had it running a set of Rainbow Germaniums active.
bose301s
bose301s
Durham, NC
SPLluminator
