FS - Sundown 2500d V2
TheFiverMan
Sundown 2500d V2
8.5/10 Few spots on mounting feet. Nothing crazy
Comes in Original box with bass remote knob.
Digital Class-D Linkable Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stability
Daisy-Chain Through Output RCA
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
RCA Line Input and Master Output
24dB Octave Crossover Slope
24dB Octave Variable Subsonic Crossover Slope
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Wired Remote Controller
Rated power output
----RMS power, 2 ohm linkable/dual mono
5000W x 1CH ----RMS power, 1 ohm mono
2500W x 1CH ----RMS power, 2 ohm mono 1200W x 1CH ----RMS power, 4 ohm mono
600W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~6dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm
500+shipping. Only trade for sundown zv4 15"
TheFiverMan
TheFiverMan
Louisville,ky
eztrez2013
