Sold FS: Subs and Amps - Zeff design, Kicker, Arc (ID) Blaupunkt
snaimpally
More stuff I have accumulated that I need to get rid of. I ship by FedEx Ground with tracking and insurance. Where practical, I double box items. Lots of references on DIYMA and ebay (snaimpally).
Cerwin Vega EXL 400.4 BNIB - $90 shipped (firm)
There are several threads discussing how this amp has been designed by Robert Zeff and that how the circuit board is very similar to his designs for Arc Audio, Clarion, and others. Lots of crossover options. I think it should be possible to run a full active setup with this amp. Bought off ebay for $90.
4 x 100 watts into 2 ohms @ less then 0.1% THD
4 x 60 watts into 4 ohms @ less then 0.1% THD
High Current MOSFET power supply
Audiophile Class A/B
Variable 12dB/oct Highpass/Lowpass Crossover
Mosfet PWM Supply
Durable Mil Spec Glass Epoxy pcb
Variable Highpass/Lowpass Crossover
Kicker KX250.2 BNIB - $125 shipped (OBO)
Bought at Frys for $150 (reg. $199) 2 years ago. It takes line and speaker level inputs.
Power (WATTS/CHANNEL), 2 Ohm Stereo: 125 x 2
Power (WATTS/CHANNEL), 4 Ohm Bridged Mono: 250
Input Sensitivity: High Level 340mV-10V, Low Level 170mV-5V
Signal-to-Noise Ratio: >95dB, a-weighted, re:rated power
Active Crossover: 12dB/Octave, variable 50Hz-200Hz, selectable high pass, low pass, or all pass;KX100.2 hig or low fixed @ 80Hz
KICKBass Boost: Variable to +18dB, centered @ 40Hz
Pass-Thru RCAs
Arc Audio Arc 10D4 - $115 shipped (OBO)
10" Dual 4 ohm voice coils. Made by Image Dynamics. I bought this new and have used it for 2-3 months. I got a better sub so I decided to sell this off.
FS: 25Hz, Mounting depth 5.5". Reccomended: sealed .65 cu ft, ported .9 cu ft. This is an excellent sounding sub.
Blaupunkt VW1000 BNIB - $115 shipped (OBO)
This was a display model at a store so the gasket and screws are missing but it does come with a very nice grill. Quite a monster of a sub. Dual 2 ohm voice coils if you want SPL. According to this post on the forum, its a good SQ sub as well. The resistance displayed is not accurate as it is on the 0-200 ohm scale on that cheapo meter.
Pics:
Kicker KX250.2
Arc Audio 10D4
Blaupunkt VW1000
snaimpally
snaimpally
Austin, TX
snaimpally
