Sold FS/ST HU's - 4 channel - amp kit - capacitor
Nova76
A 1.5 Fared cap paid $125 looking for $90 shipped
Alpine 4 channel amp MRP-F250 paid $500.00 a year ago retailes at $230.00
crutchfield review (Outstanding audio performance — you expect it when the amp is an Alpine. Alpine's V-Power amplifiers supply the high level of performance you want without shaking loose too much of your hard-earned cash.
The versatile MRP-F250 4-channel amplifier can take on a variety of roles in your system. Drive your front and rear speakers in 4-channel mode, or switch to 2-channel mode to power a couple of small subs. Want the best of both worlds? Use channels 1 and 2 to power full-range speakers, and bridge channels 3 and 4 to power a sub. Any way you use it, this amp will impress you with its strong sonic performance.
Variable high-pass/low-pass filters let you adjust the frequency output for either full-range speakers or a sub. If you're driving a subwoofer and using the low-pass crossover, a subsonic filter eliminates inaudible, ultra-low bass notes for cleaner output.
The amp's rugged construction ensures reliable performance. A heavy machined-metal heatsink keeps the internal parts cool and distortion low. Gold-plated screw terminals resist corrosion that can degrade signal performance.)
there are some mosfets that are blown on it replace those and your good to go im looking for $80 shipped retailes at 230 cost maybe 80 to fix unless you do it yourself so at the most 160 to get the amp and fix it and your good to go
also a Duel deck XD7500 dont have wires was given to me but upgraded the next day
crutchfield review(Give your dash some 21st-century style with Dual's sleek, silver XD7500 CD receiver. Its two-step, motorized faceplate (a feature usually found on much more expensive receivers) slides into position at the touch of a button — giving you access to all of the receiver's controls, the bright dot-matrix LCD display, and the oversized encoder knob. Hit the Eject button, and the display lowers itself to reveal the CD slot.
Five selectable EQ curves make it easy to adjust your sound on the fly, while audio memory lets you jump back and forth between sources without adjusting your EQ settings. Looking for more options? The auxiliary input allows you to add a portable music player, add-on satellite radio tuner, or other music source. You can even connect an external amp or powered subwoofer to the set of preamp outputs to give your music a little more thumption!)
looking for $30 shipped
let me know if interested in any of the things i have prices are not set can work out a trade for a 2 or 1 channel amp that can do at least 2K rms daily or more also 1 to 2 12" or 15" sub(s) that can handle 1.5K+ rms daily if you have something but your looking for a little more with a trade i can throw in a little cash
bump
come on ppl i know you can use some cheap stuff
cap
dual deck and
4 channel
still for sale if prices are to high let me know we can work something out
CEA-2006 Power Rating
CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 80dBA (Ref. 1W into 4Ohm): 40W x 4
RMS Power (at 14.4V THD+N, 20Hz-20kHz)
Per channel into 4 ohms: 40W x 4 (0.08% THD)
Per channel into 2 ohms: 50W x 4
Brigded 4 ohms: 100W x 2
Nova76
Nova76
Tucson, AZ
Nova76
