i got a sony cdx-gt510 cd player , works perfectly comes with mounting cage, trim ring, and harness
$50 shipped to your front door, also taking trades SOLD!!!
specs:
Frequency Response (Hz): 30 - 15,000
Stereo Separation @ 1kHz (dB): 35
Weight (lb/oz): 2lb 11oz
Depth (inch): 7-1/8
Width (inch): 7-1/8
Height (inch): 2
Preout Impedance (ohm): 220
Preout Max Voltage (V): 2
Power Ad Hoc (W): 23.2
Max Power Output (W): 52W x 4 (4 Ohms)
FM Usable Sensitivity (dBf): 9
Frequency Response (Hz): 10 - 20,000
Selectivity (400Hz): 75
S/N Ratio (dB): 120
FM S/N Ratio (dB): 67
Stereo Separation (dB): 85
THD (%): .5
AM Usable Sensitivity (uV): 30"1"]
Flip-down, Detachable Faceplate w/ Front Panel Aux In
SAT Radio Ready, iPod® Control Ready
Front & Rear/Sub Selectable w/ LPF
DSO2, EQ3 Stage 2
52W x 4 High Power
13-Segment FL Display
Switchable Red/Green Illumination
CD/CD-R/RW Compatible
ATRAC3™ plus/CONNECT™ Ready
MP3/WMA/AAC/ATRAC3plus Playback
Multi-Session (MP3/ATRAC/WMA/AAC)
MP3 ID3Tag Indication (Title/Artist/Album)
24-bit DAC
Pause function
UniLink™ Control, CD Text
Drive-S with 120dB S/N Ratio
SSIR-EXA tuner, 18FM & 12AM presets
BTM (Best Tuning Memory)
Tel/Nav Attenuation
Optional Wired Rotary Remote (RM-X4S)
45 degree install
CEA-2006 Power Compliant
specs:
Depth (inch): 7-1/8
Width (inch): 7-1/8
Height (inch): 2
S/N Ratio (dB): 120
THD (%): .5
DSO2, EQ3 Stage 2
52W x 4 High Power
24-bit DAC
Pause function
Tel/Nav Attenuation
45 degree install
