Sold FS: Sony Basstube w/ built in Amp
bizflawless
How Fly
Up for sale is a Sony Mobile ES XS-TL1
Specs
63/4" Aluminum Cone Driver w/Rubber Surround1 ohm Voicecoil Matched to Digital Amp
Compact Vent-loaded Enclosure only 16" High
Vertical or Horizontal Mount Bracket Supplied
Preamp and High Level (speaker) Inputs
High Efficiency Class D PWM Amplifier
50W x 1Ch at 1 ohm
Adjustable 50-180Hz Lo-Pass Filter
Adjustable 50Hz EQ (0 to +10dB)
Adjustable Output Level & Phase
Speaker Section
Speaker Type
Impedance
Circuit System
Inputs
Outputs
Maximum Outputs
Rated Outputs
Input Level Adj. Range
Cut-off Frequency
Low Boost
Power Requirements
Current Drain
Frequency Response
Mass
Supplied Accessories
Woofer
16 cm (61/2"), Aluminum cone type
1 ohm
PWM (pulse width modulation) circuit
RCA pin jacks; high level input cords
RCA pin jacks (pass-through)
100 W
50 W (1% THD)
0.2 - 2.0 V (RCA pin)
0.8 - 8.0 V (High level input)
50 - 140 Hz
0 - 10 dB (50 Hz)
12 V DC car battery (negative ground)
At rated output: 5A
35 Hz - 200 Hz
Approx. 3.6 kg (16 lb. 15 oz.)
Parts for installation and connections (1 set)
Height: 405 mm (approx 1515/16 in)
Width (Diameter): 200 mm (approx 77/8 in)
A friend of mine had it in his car, adds a nice little thump to your ride...
Looking to get $100 shipped O.B.O NO REASONABLE OFFER WILL BE TURNED DOWN!!!!!
Takes power ground and remote + rca or possibly high level in... man that is a nostalgic piece!! If I don't get my other nostalgia subs I'm trying to get, I may pick this up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Takes power ground and remote + rca or possibly high level in... man that is a nostalgic piece!! If I don't get my other nostalgia subs I'm trying to get, i may pick these up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yea.....pretty cool....i'd like to put this in my wife's car.//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
bizflawless
How Fly
bizflawless
Houstatlantavegas/Mars
bizflawless
