Shuriken SK-BT60 battery
This battery is right at a year old, resting voltage 12.63
SHURiKEN AGM Car Audio power Cell
This SHURiKEN 12-Volt Car Audio power Cell features a sealed absorbed glass mat (AGM) design and is perfect for 1400-watt car audio sound systems. The SK-BT60 can be used as a replacement for your vehicles standard battery or as an additional battery to provide the extra power needed for a high performance aftermarket system. It's unique spill free design allow this power cell to fit in most factory battery locations with no hazardous leaks.
SHURiKEN's SK-BT60 power Cell puts out 1500 cranking amps with a 60 amp hour rating. This battery will resist extreme heat conditions and vibrations and is 100% sealed in a reinforced ABS plastic case. SHURiKEN has designed this power cell to be used with ring terminals or a buss bar. You will love the way SHURiKEN batteries get your system powered up and ready to go!
Battery Features
12V High Performance AGM power Cell Battery
For use with audio systems up to 1400 watts
Engineered specifically to meet the needs of a high end audio system
Using AGM (Absorbed Glass Matt) technology allows the battery to be mounted in any position
Unique spill free design
Extreme heat resistance
Resistant to heavy vibrations
Super low ESR
Packed closely with pure lead plates
100% Sealed and maintenance free
Designed to be used with ring terminals or a buss bar
SAE Posts available: Shuriken SK-SAE35-100
Authorized Internet Dealer
1-year Manufacturer's warranty
Battery Specifications
Amp Hours: 60
Cranking Amps: 1500
Weight: 40 lbs.
Dimensions: 5-1/2"D x 9"W x 8"H
125 shipped firm or trade for SA-8, MA-8, VVX 8 with or without box. I will also trade for a dvd headunit. PRICE DROP $110 SHIPPED AND OPEN TO TRADES, I NEED THIS MOVED FAST! The worst I can say is no!
Battery Features
Super low ESR
Amp Hours: 60
Cranking Amps: 1500
Weight: 40 lbs.
