FS - Shocker Sig Big Gap Quad 1.2 ohms, Daily Monster!
Silver-N-Black
Shocker Sig Big Gap
18", Quad 1.2dcr, Beefy TC Sounds 8 Layer FW Aluminum Coil for the big gap Motor, 2 Spaced 8" TC Sounds Spiders w/leads sew in and a Nice Cone. 3.060" Peak to Peak before the coil hit the back plate. The sub Was Built for a daily aplication so I'll say 1800-2500w because of the spider pack as I know the Coil will handle way more. **** Sub was build by Zeuslicious.
Sub was used for about a month, motor is used with a couple of chips but good condition overall.
350 OBO, local pick only.
Wow that's really impressive. And only 200? Sheit, rare piece right here. Beautiful sub, wish I had room for an 18, glws my man
Yep. I had a few and sold them since the small gap motor gains about .7 to 1.0 dB. Found out a little later talking with Shocker Mike that that was all he ever had made... I'd have kept mine had I known they were so scarce.
a whole db!? deuym, what does the tighter gap effect to help acheive this?
The attractive force of magnets is inverse square of the distance between their poles, as I can tell it's a bit more complicated as they get closer together, but generally speaking the forces are not simply doubled by halving the distance, but squared. Hold 2 magnets apart and bring them together, notice the force gets dramatically stronger the closer you bring them together, the effect is more dramatic the closer and closer you bring them together. The tradeoff is how much coil you can throw in the gap (the ammount of metal in the coil = thermal handling), and of course if it's too tight when the coil expands from heat it'll seize up in the gap. Also when you assemble them the margin of error is almost nil. Still though, throw a big 8 layer coil on a big gap motor and it'll go really nice and take plenty of power.
If OP was local I'd own this by now.
Silver-N-Black
Silver-N-Black
SoCal
Silver-N-Black
