Sold FS: Rockford Fosgate T15004
Jager
I have a rockford t15004 for sale. Works great. It is missing the end piece that covers all of the connectors, but im sure you can find a replacement. Doesn't effect anything. Mechanically 10/10 cosmetics 8/10. small scuffs on the top, but not bad at all.
I would like $550+shipping, OR BEST OFFER! I will accept trades, I am looking for 2 12's or a 1 ohm stable amp. Doesn't hurt to try.
Number of Channels 4
Rated Power
(RMS Continuous Power) 125 Watts x 4 @ 4-Ohms
250 Watts x 4 @ 2-Ohms
375 Watts x 4 @ 1-Ohms
500 Watts x 2 @ 4-Ohms Bridged
750 Watts x 2 @ 2-Ohms Bridged
Total Power
(Sum of Rated Power) 1500 Watts
Bridgeable Yes
Crossover Controls High-Pass (HP): 40-4kHz 12db or 24db/Octave Linkwitz-Riley
Low-Pass (LP): 40-4kHz 12db or 24db/Octave Linkwitz-Riley
10x crossover switch
Infrasonic filter: 27Hz 12db/Octave
Tone Controls Bass: 0dB to +18dB @ 35-70Hz
Signal Input Low level: 2 RCA pair
Input switch: 2/4 ch.
Signal Output Low level: 1 RCA pair
Preamp Output Crossover: HP/AP/LP 12db/Octave Butterworth
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Fan Cooled
Remote Controls ParaPunch Bass EQ (included with cable)
Visual Indicators Power On
Thermal Status
Speaker Protection
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 0.5 dB
Shipping Weight 36.0 Lbs.
(16.3 Kg.)
Dimensions (HxWxL) 2.6 x 12.8 x 33 (in)
6.6 x 32.5 x 83.8 (cm)
Jager
Jager
Alexandria, MN
Jager
