I just received my order of 2 re 8's and i changed my plans before the subs arrived. So now they are for sale, both are BNIB, never left the plastic. Just opened the box for pics. The other sub in the pics is sold to a friend already.
THESE ARE THE NEW VERSION
80 shipped each
150 shipped for the pair
Specs
Mounting Depth - 4"
Mounting Hole Diameter - 7.125"
Overall Diameter - 8.25"
Bolt Hole Circle - 7.75"
Motor Width - 4.875"
Motor Depth - 1.5"
Basket Depth - 2.5"
Displacement - 0.07 cu. ft.
Weight - 6 lbs.
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.21
Total Speaker Q Value -Qts: 0.34
Free Air Resonance -Fs: 22.8 Hz
Equivalent Compliance -Vas: 27.1 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 81.2 dB SPL
Effective Piston Area -Sd: 195 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
Sorry for the large photos, but here they are.
80 shipped each
Specs
Mounting Depth - 4"
Motor Depth - 1.5"
Basket Depth - 2.5"
Weight - 6 lbs.
