FS: RE AUDIO DTS1500.1 lnib
jteske88
Item(s) for Sale: RE audio 1500.1
specs: RMS Power Rating (14.4V)):
4 ohms: 410 watts x 1 chan.
2 ohms: 700 watts x 1 chan.
1 ohm: 1000 watts x 1 chan.
Dynamic power output: 2000 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +12 dB bass boost at 45 Hz)
Bridgeable with multi link technology (MLT)
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
2-Way System Protection circuitry (thermal and short circuit)
Dual speaker terminals simplify the hookup of multiple speakers
Heavy duty brushed aluminum alloy convection fan cooled heatsink for efficient heat dissipation
Nickel-plated RCA level inputs
Nickel-plated 12AWG screw terminals
Input Impedance: 20 K-Ohm
Input sensitivity:
Low level: 100mV-6V
Variable low-pass filter (40-180 Hz, 24 dB/octave)
Subsonic filter (17-50 Hz, 24 dB/octave)
Bass frequency (30-80 Hz)
Effective damping factor: 150 @ 4 ohms
Frequency response: 17-180 Hz
Dimensions: 14-9/16"L x 8-11/16"W x 2"H
i was planning on useing but ended up just getting a xtx5000.1. This amp has been powered up to check on it from shipping. been in my closet last 6 months sitting. SO time to let it got.
Willing to trade offer up or 150+ shipping/obo
On buyer unless something is worked out.
Item Pictures: im breaking a rule right now but will update when i get home with username date in it, just wanted to get this started while im bored at work
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). i have a couple references, from buying/selling to other members.
Is this a different one you didn't use? I notice that months back you spoke of using this same amp with two subs as part of your daily driver, then later you showed photos of one of these amps that you opened up, so I'm wondering if this is a different one because in this listing you say it's only been tested to verify that it works but it's otherwise been sitting in your closet for 6 months
jteske88
jteske88
collinsville il
jteske88
